- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Stretching causes lines to go crazy
In AutoCAD 2020, I suddenly have a problem when stretching a line or lines. If I use a grip, no problems. But when I stretch and type in a distance, the lines go off at a weird angle. I have attached a video of this happening. Not sure if I have mistakenly changed a setting or what, but if anyone can help, that would be great!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Since your are trying to stretch the whole closet wall. You need to have a bigger crossing window. Play with the size of the crossing window until you get what you need.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
can we have the same lines that you tested in your video as a CAD dwg file here for testing please ?
Note : i suggest to check your AUTOSNAP (System Variable) , the Initial value = 63 .
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The skewiest third instance is because you apparently hit Enter when it said:
Specify second point or <use first point as displacement>:
and that's what you got. [How skewy that is depends on where that base point is in relation to the origin.] Don't do that when you've picked a point for the base point -- only when you've typed in the X,Y displacement you want at the base-point prompt.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I just had the same issue. I accidentally turned off number lock so when I thought I was typing in the distance to stretch I was really typing noting and then just hitting enter.
