05-05-2020
10:54 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-05-2020
10:54 PM
Try to set the wipeout under the titlebock using "DRAWORDER". Type in the command DRAWORDER and then select wipeout and then chose the option "under the object" and now select the title block, so the wipeout always stays under the title block. If this doesn't work, try attaching the file so that we can test it from our end.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
