Alfred.NESWADBA
en respuesta a: Anonymous
>> Why is it empty in Font?
Should not happen and I have not seen something like this yet.
I guess the dwg-file was created by another application and then imported into AutoCAD, and in such situations I always run command _AUDIT at first. Have you run the command? Didn't if find/correct the issue?
... would you mind uploading the file so we can look into it?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
