- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
@tilakpatel531 wrote:
…. I am going to use these patterns frequently in a lot of different drawings and so I need a pattern file which I can apply just like any other default pattern. Is it possible to use the custom pattern through Superhatch in different files?
I don't think [but you can confirm easily enough -- I don't have AutoCAD up at the moment] that SuperHatch remembers options or stores what would be the equivalent of "pattern names" or files that could be used again in different drawings, but you would need to make all the choices again in each. You would at least be able to make a drawing of a repeatable rectangular portion of the pattern you want, of Circle(s) and Arc(s), and store that as a drawing that you could bring in as a Block in different drawings to use in SuperHatch. But if "the custom pattern" refers to any of the CirclesTriGrid patterns [or a similar one with different proportions], and that's circular enough for you, then you don't need SuperHatch.
