Kent1Cooper
en respuesta a: tilakpatel531
It can't be of true circles as a Hatch pattern -- they consist only of lines and line segments.  But if a 24-sided polygon is "circular" enough for your purposes, it's likely that the open-centered pattern in CirclesTriGrid.pat, available >here<, could be re-written with proportions between radius and spacing like what you're after.  Since those proportions are different in your two diagrams, each would need to be its own pattern definition -- if you can work with the same proportion between "circle" radius and spacing, you can just use the same pattern at different scale factors.
Kent Cooper, AIA
