lbs-eeix
en respuesta a: ChicagoLooper
Thank you for your time and effort trying to help me, but maybe I haven't been able to explain what my goal is.
The MTEXT below the block is an example of text I would like to automatically display what the hyperlink description is in the block. It was there merely as an example of what I'm trying to accomplish.
We have custom programs that generate drawings with blocks(using trees and rocks as examples) and schedules, and callouts (A,B, etc.). These callouts contain hyperlinks for reasons unknown to me, but the hyperlink text (i.e. rocks, trees) corresponds to the item the callout is describing. The callouts need to be positioned next to the item for which they are describing.
I understand your idea of adding a "type" attribute to the block with the description,
Ideally, I would like some text which comes in as part of the callout block which displays the hyperlink text to make it much faster to position them. If that is not possible, perhaps a way to keep the tooltip popup windows from disappearing which show what the hyperlink says.
I tried adding an attribute to the block(yes, I do know how to do that) but cannot find a way to link the attribute in the block to the hyperlink which is assigned to a single inserted instance of the block, not in the block itself. I am aware that you can use fields in text to display object properties, such as the area of a closed poly. I was merely wondering if anyone knew a way to get it to display the hyperlink "text to display".
Even though it's hard(for me at least) to describe, my question is fairly simple: Is there a way to make an attribute in a block that can display the hyperlink text which is applied to a particular individual instance of that block?
