ChicagoLooper
en respuesta a: lbs-eeix
@lbs-eeix wrote:
I'm looking for a way that I could use text to display what the hyperlink description is without having to hover over the block.
@lbs-eeix wrote:
.....I'm using these blocks to tag objects.....
Based on what you have described your block with the hyperlink is giving you what you want but not displaying it how you want. If this is correct you need to quit using that block. Yes, ditch that block altogether.
Instead use mtext. You don't necessarily have attach your hyplerlink to a block, you can attach it to mtext too.
Mtext is capable of holding a hyperlink.Mtext is capable of holding a hyperlink.
In the image above, the 'contents' of the mtext is the actual link itself.
Chicagolooper
