lbs-eeix
en respuesta a: pendean
I'm looking for a way that I could use text to display what the hyperlink description is without having to hover over the block. The block below (A) has an attribute definition in it and the "A" is assigned when the block is inserted, and different hyperlinks are assigned to each instance of the same block. Ideally the text below the block which shows the hyperlink definition could be inserted into that block.
The situation is I'm using these blocks to tag objects in our drawings. The letters correspond to a schedule which describes the object. The blocks are generated automatically and contain hyperlink text which defines what they correspond to. Instead of hovering over the block for the hyperlink text to appear, I just want a way for that to be displayed at all times, essentially pinning the tooltip window that pops up, or with text on a non-plotting layer.
