330 Vistas, 1 Respuesta
Comando equivalente a vista di base su windows su mac
Buongiorno, volevo sapere quale è effettivamente il comando che sostituisce viste di base (windows) nel mac dato che non lo trovo ? Ringrazio in anticipo.
Nicola
Translated by google
Command equivalent to basic view on windows on mac
Hi, I wanted to know which command actually replaces base views (windows) in mac since I can't find it? Thank you in advance.
Nicola
Etiquetas (1)
vinodkl
en respuesta a: Anonymous
VIEWBASE is not available in AutoCAD for Mac.
check these links:https://forums.autodesk.com/t5/autocad-for-mac-forum/base-view-for-mac/td-p/5935504
                               https://forums.autodesk.com/t5/autocad-for-mac-forum/viewbase-command/td-p/9011300
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
