MarkSanchezSPEC
621 Vistas, 2 Respuestas
Default folder Location for Open
We have a Citrix virtual environment that has the local C: drive set as off-limits to the user, meaning they do not see the drive in Windows nor can they browse any of the contents
Because AutoCAD appears to default to the "Documents" folder (located at "C:\Users\LOGIN\Documents"), our user's get the attached message, which is from the OS and likely due to it attempting to open the "Documents" folder.
When the user clicks OK, they are able to continue and browse to the areas they do have access to. However, is there any way we can totally avoid the message and default AutoCAD to browse to another drive they do have access to?
rkmcswain
en respuesta a: MarkSanchezSPEC
Perhaps this would help?
MarkSanchezSPEC
en respuesta a: rkmcswain
Thank you.
