scot-65
en respuesta a: Anonymous
There are two text modes:
Font assignment with a fixed height greater than 0 (zero) and
Font assignment with a fixed height of 0 (zero).
Each of these behave differently when editing.
Look into TEXTSIZE and DIMTXT when fonts are assigned to 0 height
otherwise assign a fixed height greater than zero.
TEXTSIZE
Sets the default height for new text objects drawn with the current text style. TEXTSIZE has no effect if the current text style has a fixed height.
DIMTXT
Specifies the height of dimension text, unless the current text style has a fixed height.
>>I can adjust text height, which seemingly does nothing.
Not to existing text objects, however dimensions will update via
command -DIMSTYLE "Apply" and select the existing dimensions.
Any new text objects will reflect the height assignment of either
of the two modes shown above.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
