lgallantHCE9F
3356 Vistas, 4 Respuestas
"Unsupported DGN file. Only V7 and V8 are supported" when trying to insert a DXF
Trying to insert a DXF file into a DWG template and get the following message: " You have selected an unsupported DGN file. Only V7 and V8 files are supported."
The DXF is coming from an outside company and has been generated from a 3D model (these are roof outlines). I expected to be able to insert the DXF just fine. I use the full version of AutoCAD 2018.
When I attempted to attach the DXF on this thread, the Autodesk Forums webpage removed it, stating the attachment's "content type (application/x-dxf) does not match its file extension and has been removed". Many thanks for any assistance!
