- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
My Text is Too Small. How Do I Fix It?
I am drawing an object in AutoCAD 2016 and must include text for instruction. However, after typing in my text, it shrinks down to microprint. How do I get it to normal size?
I first encountered this problem with dimension lines, but to solve the problem, I simply had to go to manage dimension styles, then modify, and adjust the scale to 25.4.
Again, I encountered this problem with leaders but solved the problem by doing the same as above (but for leaders), adjusting the scale to 15 to achieve a close-to-equal size (the scale of leaders vs dimension lines is not the same).
So, now that I have encountered this problem with text, I assumed I would have to simply adjust the scale through the same meathod as above, but I cannot find and option to adjust the scale.
I am working in milimeters. I am sure the answer is simple, but please be patient.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Yes, text style is what I was attempting to use. I see there, I can adjust text height, which seemingly does nothing. I adjusted it to 100 and got nothing. Width factor does do something, but simply multiplies the width, of course.
It is not particularly the text height which I am attempting to amplify; it is the overall text which I am attempting to amplify.
I apologize for any misspellings, I am in a considerable hurry today.
I have included a screenshot. The white blob is the text which I wish to bring to normal size.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Are you using TEXT or DTEXT or MTEXT commands, or something else for this "text"?
What text size and sizes are being used with the leaders I see? Does MATCHPROP fix it if you pick one of those then your tiny text?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Font assignment with a fixed height greater than 0 (zero) and
Font assignment with a fixed height of 0 (zero).
Each of these behave differently when editing.
Look into TEXTSIZE and DIMTXT when fonts are assigned to 0 height
otherwise assign a fixed height greater than zero.
TEXTSIZE
Sets the default height for new text objects drawn with the current text style. TEXTSIZE has no effect if the current text style has a fixed height.
DIMTXT
Specifies the height of dimension text, unless the current text style has a fixed height.
Not to existing text objects, however dimensions will update via
command -DIMSTYLE "Apply" and select the existing dimensions.
Any new text objects will reflect the height assignment of either
of the two modes shown above.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.![]()
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
FYI
I noticed that you posted the same question in other forum. You don't have to as it may waste your time and others, who are willing to help.
I had a reply there. You may like to have a look.
HTH
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
