tmoxam
en respuesta a: dgorsman
yes descriptions need to be short. but, the only place you will see what happened is in the rev block. there is no other location for this data.
the difference is....
1.   "Change qty item 6, was 4 now 3"
or
2.   "Change qty item 6, was 4 now 3, added items 33, 34, removed items 16, 22, 31"
they both have to fit in the same 2-1/2" space.
if i use multiline attribute...the text is constant (.06") and starts in top left corner. If i use #1 above, the text is small and in the top of the frame. If i use #2 the text is 2 lines inside the space at the same font size as the first.
What i am WISHING for is a condition where the text would be a certain size and centered vertically until it exceeds the  boundary and then reduces text size and creates a new line to remain inside the text boundary and then that text would also be centered vertically.
thanx
