tmoxam
740 Vistas, 3 Respuestas
Multi-line revision block
i would like to create a revision block with..
rev number
rev description
rev date
rev by
attributes.
For the description i would like to have an attribute that is "wrapped" in the space provided. By that i mean if i have a short description it would be centered in the space. If the change was long i would like to "wrap" the text in multiple lines in the space provided.
Can this be done? What is the command?
Alternately, can i make a block with multiple attributes for description and then the block size would change depending on how many lines were needed.  I have a feeling this may be a dynamic block but, i have no experience with them.
Which way should i go to accomplish the task?
cheers!!
