- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Greetings,
I was wondering if there is a field that will provide the filename of a detail that is being added to a sheet in the SSM. Our setup is to have each detail in its own file, we then create a view in that drawing. Then through SSM we have it as a model view. Then it is added to a sheet. When we add the dynamic call out block to that sheet, we want there to be a field in there that provides the name of the file that the detail is in. Is this possible? I may be overlooking the field in the options but am not having any luck. Thanks in advance for any responses.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous ,
This is an old video, but have a look and see if this helps.
- Youtube Video on Sheet Set manager - Automate Callout Label Data ; https://www.youtube.com/watch?v=DJyfwJXdK2M
If this is not the answer, can you give me little bit more on the details, any screenshot would be helpful to understand your inquiry. Thank you,
Kindly 'Accept as Solution' if this resolves your issue.
Sophia Lee
Global Product Support Specialist
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I found what I was looking for.
The field to use to list any object's filename (xref'd detail, for example) is:
Field Category: Object
Named Object Type: Block
In that list will be the filenames of all reference files in the drawing among many other things.
