Volker_C
en respuesta a: Anonymous
Thanks for posting the file @Anonymous, although I don't quite understand the issue, I would recommend that you do not use an annotative text style within an annotative block. If the block is annotative, then the contents within the block - the text - will scale with the block.
In case it will help, the In-product documentation pretty much sums up how annotation scaling works:
About Annotation Scale
In a nutshell, objects should be drawn at full size so that they will appear at the size expected when plotting 1:1. If the object is annotative, you shouldn't have to do anything but adjust the paperspace viewport annotation scale.
That said, I'm not sure if this is answering your question or not. If not, it would be helpful to know the block name that does not work as expected, as well as steps to recreate the issue.
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker C.
CTS Technical Enablement Specialist | AutoCAD
Autodesk Customer Council | Only One AutoCAD | AutoCAD Blog
