508 Vistas, 3 Respuestas
Way to enter text from bottom up
Hi, new to the forum and to autocad.  I have been teaching myself to help out at work during this crazy time.  I have searched and searched and cannot find any help or answers.  I am creating 2D drawings and want to insert general notes at the bottom of the space, but I want the text to enter from the bottom and and auto number ascending as it goes up.  Is there anyway to do this? Or do I really have to manually do it and manually number my list?
Any help would be great.
Thanks in advance.
Mike
pendean
en respuesta a: Anonymous
Do you mean you just need to set your justification to "bottom left" before you start typing?
There is no ability to write bottom line then line above it, then line above that in AutoCAD AFAIK. What software did you use previously that did that?
en respuesta a: pendean
No, I'm not trying to set the justification or alignment, but as you said in your second statement.  Start at the bottom and as you hit enter the next line starts above it.  I know you can do this is solidworks.
I've been told that when you insert notes at the bottom of the sheet they should ascend upwards so it is easier to add to it later and so that the insertion point doesnt change.
pendean
Maybe you misunderstood the intent of the advice? Ask the advice giver for guidance, I am not aware of such a feature unless you just want to have a multi-lines of single text or attributes that you fill in individually after the fact.
