- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
change the visual style in the drawing with the issues to "2D Wireframe", you also can use command _GRAPHICSCONFIG to turn off hardware acceleration, this reduces the effect you are having on the display.
But to make sure ... the zoom depth you are using is far beyond the possibilities of double precision calculation. When you are zoom that close to an endpoint, you even can't see a coordinate difference between your left and right border of your display (try it, zoom in that close, start command _DIST and then pick a point on the left side of your display and then on the right side ... I bet the distance you get as result is 0.00000).
Zooming more and more close does not make a sense and is reaching then the physical end of the display list, that's why you see the jumping graphics.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
