jayhar
en respuesta a: tesfaye_kebede
Hi, @tesfaye_kebede
I recommend turning on Autosave and setting the increment to 1 minutes. SAVEFILEPATH to be set in local drive create new folder name as Autosave. This is for future work.
Always keep a backup in a different location (not the same drive)
Install latest updates and service packs from autodesk.
recovering a drawing in a higher version of AutoCAD
No use you upoad .dwg here, because backup file saved in another system.
drawingrecovery is maximum
Revit Architecture Certified Professional
Thanks You
JAYHAR.M.J
Team Leader
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Etiquetas (1)
