pendean
en respuesta a: Anonymous
Doing it in plain AutoCAD is like doing it with a pencil and paper: manual drafting from scratch.
For hatching to work at its best, you actually need to create the boundary that encloses the area then select that boundary. If you only wish to click in an area and let AutoCAD guess for you, you have to do a lot of things and then it may not still work:
- ensure the entire area is on screen.
- freeze all layers that do NOT need to be on to define the area to hatch.
- Ensure your area is actually closed. This is a manual process. You might be able to set a "fuzz factor" so that gaps are skipped over, but you'll have to guess at the correct size, this may take several tries.
HTH
