artc2
en respuesta a: cadffm
Sebastian is right, AC1500 should not be used in a dxf file (outside of Autodesk) because it specifies a format that was only used internal to Autodesk during the development of that version of AutoCAD. It's possible that subsequent versions of AutoCAD won't even read such files correctly because AutoCAD doesn't need to support internal development format versions since files of those formats are only supposed to be internal to Autodesk.
As Sebastian suggests, Ac105 should be used as the format value for that version of DXF.
