R_Tweed
en respuesta a: Anonymous
There is another option available that doesn't require you to learn a programming language. If you are familiar with excel the calculations are pretty easy to do. The max, min and average functions are straight forward.
1. use the dataextraction wizard to extract the values by layer to an xls file.
2. open the xls file and add your functions.
3. You can also import the data into a table within autocad and add formulas at the bottom. (something to explore)
