502 Vistas, 6 Respuestas
Calculating numeros text statistics
I have this layer, with numeros text objects and I´m trying to figure out statistics about them
for example
here I want to calculate Max, Min and Average of the selected texts
Anybody knows how do I do it?
ВeekeeCZ
en respuesta a: Anonymous
Yes, learn to program! Prob the simplest would be a LISP:
(vl-load-com)
(defun c:TextStats ( / lst)
  (if (and (setq lst (ssget '((0 . "TEXT"))))
	   (setq lst (mapcar '(lambda (x) (distof (cdr (assoc 1 (entget x))))) (vl-remove-if 'listp (mapcar 'cadr (ssnamex lst))))))
    (princ (strcat "\nMin: " (vl-princ-to-string (apply 'min lst)) " - Max: " (vl-princ-to-string (apply 'max lst)) " - Avr: " (rtos (/ (apply '+ lst) (float (length lst))) 2 3))))
  (princ)
en respuesta a: ВeekeeCZ
Hey, Thanks for the reply!
I'm struggling a bit with your solution,
Iv'e put your code in the command line and nothing turned out,
I guess that's not the way to do it
could you please be more specific?
I must say that I usually dont work with CAD so I'm not really from that world
ВeekeeCZ
How about use google to learn how to run a LISP ?!
http://www.lee-mac.com/runlisp.html
Jeez, what´s with the attitude?
Whatever,
thanks for your help
ВeekeeCZ
Well, there is no other solution than write a program that will do that.
And you're not even capable to search how to use it. So. Sorry that I wrote that program, I should not.
R_Tweed
There is another option available that doesn't require you to learn a programming language. If you are familiar with excel the calculations are pretty easy to do. The max, min and average functions are straight forward.
1. use the dataextraction wizard to extract the values by layer to an xls file.
2. open the xls file and add your functions.
3. You can also import the data into a table within autocad and add formulas at the bottom. (something to explore)
