sundaram1087
858 Vistas, 2 Respuestas
Insert Block In Autocad Using C#
Hi
 I tried to insert the block in autocad by Using C# in COM Object method. in that am getting error that "Key not found"
This is my function
public AcadBlockReference NewblockInsert(Double[] Inspt, string BlockName )
double Dimsacle = 1;
AcadBlockReference BlkInsert=null;
try
BlkInsert = (AcadBlockReference)CadDoc.ModelSpace.InsertBlock(Inspt, BlockName, 0, 0, 0, 1);
catch(Exception ex)
MessageBox.Show(ex.Message);
return BlkInsert;
Could you please provide the solution for that
Regards
Shunmugasundaram
ilia.borisov
en respuesta a: sundaram1087
Are you trying to insert already existing block or you first create block and then try to insert it with that method?
sundaram1087
en respuesta a: ilia.borisov
Hi
Existing block only
Regards
Shunmugasundaram
