- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Thanks for your response.
I am on a desktop computer, not a laptop, so I am already using a standard keyboard.
A lower case "w" does not cause a problem and responds as you would expect, just typing a w in the command line. (To clarify, this only happens in commands. If I am working in a text box, the CAPS LOCK W types a "W" without bringing up the NAVWHEEL.)
I have already started using the "all caps" option in an attempt to limit having the CAPS LOCK engaged.
The only thing I have not tested is duplicating the issue in other applications. I'm not even sure the best way to test this, as I don't know of another application that uses SHIFT+W for anything other than typing a capital W. I tried to create a shortcut in my word proccesor, but SHIFT+[any letter] is not available for keyboard shortcuts.
