ChicagoLooper
en respuesta a: jackshield
You applied a HIDDEN Visual Style to your viewport. You should make your viewport visual style 2D Wireframe and apply HIDDEN to the viewport Properties in the Properties Palette.
  1. Change the visual style of each VP from Hidden to 2D Wireframe.
  2. While on your layout tab, select the VP so the description at the top of the Properties Palette changes from No Selection to Viewport.
  3. In the Properties Palette, under MISC section, change 'Shade Plot' from Hidden to As Displayed.
Go to print preview.
Alternatively:
  1. Make the visual style for each VP HIDDEN.
  2. Select a VP so 'viewport' appears at the top of Properties Palette.
  3. Under Misc section of Prop Palette, make Shade Plot WIREFRAME.
Chicagolooper
