brenda
411 Vistas, 6 Respuestas
When inserting a detail with multileader text, the text moves
I have a detail that was drawn in 3/4" scale with multileader text.  If I try to copy paste or wblock the detail and move it to another sheet, the text moves to somewhere else on the sheet.  I tried to use annoreset and attsync but they didn't seem to do anything.  I tried to change the sheet scale and then insert the block but that didn't change the problem.
I have attached a screen grab to show what is happening.  I have been using AutoCAD 2015 and 2016 with the same results.
Thank you for your help.
