03-25-2020
08:03 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-25-2020
08:03 AM
We are an underground limestone mine the deposit is relativity flat and uniform so we don't have much need for 3d modeling, every thing is viewed in plan view. Most survey data is used to determinant where surface points relate to underground points for positioning of shafts and the also mapping the pillars of the mine. I would like to be able to create points like the ones in the cad file I attached.
i have found a way of creating a script formula in word that will import all the points with a description the problem is i can't create a block out of each point location.
I haven't given survey layout to much thought yet but do you think i could use data extraction to import into my data collector?
