en respuesta a: imadHabash
Yes I know how to do that but when I have over 20 computers to set up, it becomes a hell of a task each year to set up and it doesn't fix the problem of a new user on the computer opening autocad and wiping out the existing profile on the computer. I was after some way of setting it up on the initial install of autocad on the computer to change the setup to a persons profile. Then if someone else logs onto that computer and uses autocad for the first time it will not wipe out the other persons profile and the first person will still be able to open autocad and autocad go directly to the first persons setup/profile.
