365 Vistas, 2 Respuestas
Profile changes on computer for multiple users
At our factory we have multiple users on each computer. Each time a new user opens autocad on a particular computer the program resets up the autocad and throws the other users profile for autocad off that computer and they have to reload their profile for autocad. My question is there anyway of setting up autocad during the installation of autocad on the computer to get it to look at a persons profile location on the computer/network each time autocad is opened and grab their profile instead of the generic autocad profile. Then when autocad is opened by a person then it will just go straight to their profile & cuix even if someone else has opened autocad in the mean time and changed the autocad settings as the new person would have their own settings on the network. This way the users could use any computer and have it setup to their profile with have to load their profile each time they go to a new computer.
imadHabash
en respuesta a: Anonymous
i suggest from  OPTIONS >> Profiles tab to start Import your profile to the current PC . >> Click <<  and  >> Click <<
Imad Habash
en respuesta a: imadHabash
Yes I know how to do that but when I have over 20 computers to set up, it becomes a hell of a task each year to set up and it doesn't fix the problem of a new user on the computer opening autocad and wiping out the existing profile on the computer. I was after some way of setting it up on the initial install of autocad on the computer to change the setup to a persons profile. Then if someone else logs onto that computer and uses autocad for the first time it will not wipe out the other persons profile and the first person will still be able to open autocad and autocad go directly to the first persons setup/profile.
