pietro.pedone
en respuesta a: __patrick__
Thank you @__patrick__ -- if you're opening the master file from the network directly, then the poor performance is most likely due to this one being accessed.
The closest option available in AutoCAD at the moment is using Demand Loading as described here: About Improving Performance When Using Xrefs. You should be able to improve performance this way. You can test by comparing the same file on the network and locally after remapping the relative paths.
Another option is to use ETRANSMIT. If you choose to keep the folder structure when creating one, you should be able to replace the drawings in the correct location at the end of the day.
Hope this helps!
Pietro.P
Global Product Support
Autodesk Knowledge Network
