pietro.pedone
en respuesta a: __patrick__
Hi @__patrick__ , where are the master files that you're trying to work with?
Are they locally stored, while the xrefs are stored on the network that you're accessing via VPN?
Or is also the master drawing stored on the network you're accessing via VPN?
Did you check if the XLOADCTL variable is set to 2? This enables "Loading with copy", which should improve performance when using reference files stored in a network.
Pietro.P
Global Product Support
Autodesk Knowledge Network
