- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Tks for the reply.
Most of them are relative but not all. Some files are copied from complete other works to avoid doubles. So then its easier to use absolute.
The thing is. When you work at the office all works just fine, either absolute or relative.
Working at home all changes.
Absolute finds items over the vpn. But working over the vpn is way to slow.
Relative needs them to be copied locally. Following the original dir structure which needs to be recreated dir x dir.
Would appreciate an AutoCAD option that handles all this.
A "work local" button. Which saves all used xref files in some local temp cad directory, temp updates the xref locations to these folders, checkes each x minutes for updates on the original xref path over the slow vpn and at the end of the day uploads the single file you worked on leaving the orignal xref.
