__patrick__
1775 Vistas, 10 Respuestas
Work "locally"over vpn, maintaining xref's
Installed AutoCAD locally and enabled a VPN to my office's server. Most cad files have a lot off xref's.
Is there a simple way to let's say, click  "local", so autocad copies used files locally in a temp directory correcting the xrefs paths, and each once in a while checks if there are changes on the xref ?
Then when you click "online" it uploads the file you are working on .... and that's it.
Doing this manually seems a stone age solution. Changing the xref paths, xref per xref, means losing a lot off time.
Looked into A360 & co but I am not keen on uploading all ongoing projects to A360.
Prefer to use my own server.
