mrgrotey
232 Vistas, 3 Respuestas
How do I customise the smaller, condensed QAT? (when no drawing is open)
I am very capable of customising the regular quick access toolbar when you are working on a drawing but I want to change the 'NEW' button to 'QNEW' on the condensed version of the QAT when there aren't any drawings open (It only shows New, Open and Sheet Set Manager) but I can't figure out how to do that.  Any changes I make to the regular one do not transfer on the the condensed one.
Any idea?
pietro.pedone
en respuesta a: mrgrotey
Hi @mrgrotey , I'll check if that toolbar can be customized as well.
In any case, the QNEW command is already the one included in the "condensed" version (you can see that by hovering over the icon). Any reason you were looking to use the QNEW command specifically?
Pietro.P
Global Product Support
Autodesk Knowledge Network
mrgrotey
en respuesta a: pietro.pedone
Hmm thats odd.  it worked just like NEW (opened up a dialogue box not just loading my default template) until I changed the STARTUP variable now it acts correctly like QNEW should.
The reason was simple a combination of laziness and convenience.
Thanks any way! :cara_con_una_leve_sonrisa:
dan908
Just jumping in to finalize details - the QAT when in zerodoc state or on the start page can only be edited to show 0-4 icons - qNew, Open, Open from Web and Mobile, and Sheet Set Manager. It is hard coded. There is no other editing available in CUI.
Dan
AutoCAD Quality Assurance Manager
