1656 Vistas, 8 Respuestas
Importing survey points from excel in to multiple blocks
I have around 4000 points in excel in the format shown in the table below. I would like to be able to import the Point with a description that includes the Point ID, the Elevation and Description.
 I have attached a file with points that have already been imported using Carlson Software pulled directly from the surveying data collector. We ware wanting to bypass the need for using Carlson and just use AC for our survey data.
Carlson would create a block with the point and the description for each point. With the three parts of the description in different layers
Im looking for a way to do the same thing by importing an ASCII file or an excel file and have AC create blocks the points and the descriptions for the points in separate layers.
I’m a one month user of AC and have know idea if this is even possible.
Thank you for any help
Point IDXYZDescription
11903582.4535-2243.071312.77NUCRSHRRKBX
11904423.192-2272.821311.58CRSHRRKBX2
11905500.4956-2206.111312.8TP3
11906163.441-2258.231307.05TP4
Etiquetas (1)
