03-20-2020
05:39 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-20-2020
05:39 AM
Note that when you create a polyline its first vertex will have the xyz coordinates of the point you specify but subsequent vertices will be project to a plane parallel to the current UCS. The location of that plane is determined by the first vertex. For example, let's say you have some geometry that does not lie on the current UCS and you start to create a polyline using OSNAP END. The first vertex will snap exactly to the vertex of the end of line you pick but the next point you pick will be project to a plane parallel to the ucs that passes through the first vertex. In your example if the rafters lie on a plane but a different UCS is active when you create the cross members of the truss, the trus members will lie on a different plane.
lee.minardi
