tiger4956
1400 Vistas, 3 Respuestas
Looking for Shortcut to adjust MTEXT width when using QLEADER
Question:  Is there a keyboard shortcut that will fit the text width to the text in the mtext editor?
In the Autocad mtext editor there's a little symbol at the end of the ruler bar that looks like a left & right solid arrow.  If you double-click it the text width auto-adjusts to the width of what you've already typed.
I'm using Autocad MEP and Dragon Medical voice command with Autocad for almost all commands.  So, I try to find a way to do everything with keystrokes instead of the GUI.
I'd like to use QLEADER because it works well with voice command.
I realize  MLEADER  has an advantage because the mtext editor opens with the mleader command but I'd still like to use QLEADER because it's fast and simple.
Rob
