654 Vistas, 1 Respuesta
03-19-2020
03:14 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-19-2020
03:14 AM
How can i unload a VLX or undefine it?
using this file from here -https://payazed.wordpress.com/2015/06/02/xrp/
I've loaded a file called XRP.VLX through appload
I've tried to move it out of the original folder however the command "XRP" still remains and when it's typed/executed CAD crashes/goes into the spinning wheel. Is there a way to remove it as a defined command?
Tom
¡Resuelto! Ir a solución.
03-19-2020
03:35 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
03-19-2020
03:35 AM
HI,
you can search in your PC and follow XRP.VLX , then you can delete it OR while AutoCAD is active you can check your Startup suite from APPLOAD command >> Select and Remove .
Imad Habash
