CADmgrMike
380 Vistas, 1 Respuesta
Mtext and tab underline
I have some mtext that we use a Tab to underline a certain length.
I've been converting these to ttf instead of shx and now if these mtext objects are a block, the underline shows way above the text object. (see attached)
If I explode the block. the underline goes back to the correct position.
Any way to fix this?
I know about Ctrl-Shft-space to create underlines, but would prefer the Tab method if possible.
Mike Porter
https://provostandpritchard.com/
sophia_lee
en respuesta a: CADmgrMike
Hi @CADmgrMike,
This is AutoCAD Forum website, you may refer to Civil 3D Forum link below and upload your issue.
If you are referring to this Ribbon icon for Undrerline as below, i can help, just let me know.
Please 'Accept as solution' if this is helpful. :cara_con_una_leve_sonrisa:
Sophia Lee
Global Product Support Specialist
