- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
@pendean's suggestion that something, somewhere, is different between the machines that work & those that don't has to be correct. It is not necessarily something obvious, or easy to track down, but it seems logical that there has to be something different. Could be an error when AutoCAD was installed- have you tried resetting to defaults, running with add-ons disabled, re-install, etc? Could also be a Windows system error, have you tried sfc command, and dism tools if necessary? If the systems were all created/cloned from a common image, could be 2 out of 6 didn't clone quite right....Could be an error in network authentication, could be corruption in Windows user account(s).... Your IT folks may have some digging to do (maybe through a lot of "could-be's", unfortunately)....
