murray-clack
en respuesta a: cmorrone.cjl.ytn
First, try doing a RECOVER and AUDIT on the drawing you are trying to attach as an XREF because there may be some corruption.
Second, instead of using the xref palette, try using the command CLASSICXREF
Third, in the CLASSICXREF dialog box, let the dialog box control the parameters of how the xref comes in. Which is say, enter the insertion, scale, and rotation values in the dialog box, don't let the function pause for user input (sometimes the pause will lock things up - especially on large xref files)
