Alfred.NESWADBA
en respuesta a: 8633115
>> it asks if I want to include custom settings from
>> networked locations, what does this mean?
Some companies have parts of the customization on the network, like fonts, like plotter PC3/PMP-files and stuff like this.
When you transfer now settings to one of your other workstations the question is:
Does this workstation have the same network environment, so it can access the fonts, PC3/PMP-files, ... ==> then these files are not needed to be copied into the transfer-package.
If your laptop is for homework, and so you need the fonts, plotter-files, ... on your local system or at a different path as you can't access the same network ... ==> then you need to copy these files from the network into the transfer-package too.
Hope this makes it more clear!
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
