- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Autocad doesn't take commands
My autocad mixes up commands.
For example when I type in "m" for move it almost immediately changes to "offset" or when I type in "J" for for join it says "Unknown command 'VKV'. Press F1 for help".
When I change "PICKFIRST" to "1" (although it was still 1) and I restart the computer the issue is temporally solved until it starts all over again....
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
please start command _INPUTSEARCHOPTIONS and disable "Autocorrect" as well as "Enable Mid-string search" within "Enable AutoComplete" ... better?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Alfred,
It was good until now...
When I type in "j" it says "unknown command" or when I type in "co" it changes to offset. Or when I select an object and type in move and hit enter, I'm asked to select objects.
Brigi
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
This can be an issue with the settings mentioned above (like _INPUTSEARCHOPTIONS) or a defect/incorrect ACAD.PGP file or a loaded app/plugin.
If you have not done too many customization then you can reset the AutoCAD profile to default (>>>details<<<).
- alfred -
Alfred NESWADBA
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I've done what you suggested first but the issue came back.
So, I've reset autocad to default yesterday but I have a plug-in I had to reinstall. It's called VBexpress and it's for reinforced concrete design.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Did it work then (before reinstalling the plugin?
- alfred -
Alfred NESWADBA
