- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Yes im sure a lisp can be made to that. But the bigger issue is your office has no standards. You guys need to make a blank template file that's saved on a share drive. This template would have all layers, dim styles and other typical things you guys use in your drawing. That way everyone is working with the same stuff from the start of the drawing. Anyone drawing at 0" tolerence should be sent back to school.
One thing you could do is...
1)find a drawing with the dimension setup that you like, pick an existing dimension right click. copy.
2) Paste that dim in the new drawing.
3) use Isolayer command to isolate only the dimensions layer.
4) use Match Properties command, select the good dim use brought from the other drawing, then highlight all the bad dim. and bam there all the same
