- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
>> I think one of them shows transparent object.
Well, we now have to make sure you don't have an issue with your PDF viewer!
Otherwise we are searching on the AutoCAD side and it can't do anything better!
>> It also plots differently using different PDF presets, AutoCAD PDF
>> (High Quality print) and DWG to PDF. But I guess they are supposed
>> to be different? Anyway, I'm using AutoCAD to PDF one.
After fresh installation yes, they are different, but when you start command _PLOT, select "DWG to PDF.pc3" and then click on "PDF Options" you can set these parameters to be equal to the "AutoCADPDF (High quality..."
>> I have a block with a wipeout in it and the wipeout has a transparency set to 50
Wow, "wipeouts" already have their own issues, making them then transparent is a critical mission.
From your screenshots and this statement:
>> Using PLOT (in Preview)
please do a real plot, because a preview can look different than the real output.
I would now start with this:
- Draw one polyline, give it a width of 1 and a length of 5
- Draw a second polyline with the same width and length, but in a way it crosses the previous one.
- Assign the first polyline color red
- Assign the second polyline color blue + make it transparent (70%)
Now run command _PLOT and command _PUBLISH, compare these 2 PDF-files .. what are the results?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
