en respuesta a: Alfred.NESWADBA
Yes, same PDF file looks different on 2 viewers. I think one of them shows transparent object. It also plots differently using different PDF presets, AutoCAD PDF (High Quality print) and DWG to PDF. But I guess they are supposed to be different? Anyway, I'm using AutoCAD to PDF one.
Before I upload the drawing, let me ask you one other question. I have a block with a wipeout in it and the wipeout has a transparency set to 50 and it is also sent back behind the other layers within the same block. Now when I place this block elsewhere in the drawing, the wipeout should cover the other layers in the file except the one within the block because it is behind them, correct? Another words, it should show anything behind the block with transparency, but NOT the layers behind the wipeout sits in the block.
At least that's how I understand it and when I use PLOT command, it shows it that way. But when I use PUBLISH and and I'm publishing other sheets within the same drawing, it stops behaving that way.
I'm attaching two pictures, first is the block in PLOT PREVIEW, showing exactly how I think it should work and how I want it. The second is result after I use PUBLISH command.
Using PLOT (in Preview)Using PLOT (in Preview)Using PUBLISHUsing PUBLISH
