Alfred.NESWADBA
en respuesta a: Anonymous
>> Something must have happened in my setup I'm not aware
>> of. Since a few days ago, when I publish the drawing (8 sheets)
>> it doesn't publish with transparent hatches
Can you please try the same in a new drawing, just 2 layouts, hatches with transparency, pagesetup with "plot transparency" set to on ... then _PUBLISH (using PDF output)
If that works, then please try again the same with your project and use "PDF" as output.
If that does work then it has somthing to do with your selected output device/settings.
If that does not work ... any chance we can get your dwg-file to test it on our systems?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
