>> No you are not correct.
Well, referring what we know until now:
Last message:
>> It's like I never did the command. I can keep working, just like normal
And that's what you wrote in your initial post:
>> I have to close out of autocad
So that you can work after you started the command is a new information :cara_guiñando_un_ojo:
What happens if you start command _.PAGESETUP (with underline and point?)
Can you please start command _ABOUT and show us a screenshot from this dialog so we know exactly which type/version/update of AutoCAD you have.
Other questions:
  • have you migreated settings from previous version of AutoCAD?
  • have you used/accessed PC3 files from previous versions of AutOCAD?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
